problems with the A15
From Midway City, California
hello gents,
ive been having some problems with my A15 for a while now and its pissing me off. the car runs fine when its cold, but after it warms up, it will bog down at low RPMs, and if i try to take off from idle, and it will turn off at idle if i let it sit. any suggestions on what to dd, or check?
thanks in advance
Posted on: 2012/10/26 18:11
if it was easy to restore, they would call it chevrolet
don't piss off America, or we will bring democracy to your country
Re: problems with the A15
Not too shy to talk
From SOUTH AFRICA
Hi M,
It seems to be a common issue, (my personal opinion)as my A15 wil run fine then out of nowhere it will start to stutter as if some blockage in the fuel line. I have cleaned my fueltank and fuel lines, but it still persisted. In the process of overhauling the engine, dropping CR and fitting weber 36 dcd 7 in the meanwhile. What seemed to help at stages was to let the revs pick up to about 5000rpm a couple of times( as if to clear its throat) then mine went fine again for 100-150 km. really odd! good luck
Posted on: 2012/10/26 19:39
i dont think its a fuel issue, i recently replaced all the lines, and put a new filter, and a weber 32/36.
im thinking it might be a bad coil, im going to try the one from my dad's 620 tommorow.
Posted on: 2012/10/26 19:43
Not too shy to talk
From SOUTH AFRICA
Check your wiring inside distributor as well. Had that once, took a while to find it as it seems to be intermittend.
Posted on: 2012/10/26 19:54
So it had the same symptoms with the original Hitachi? And now with a Weber it does the same thing?
Posted on: 2012/10/26 21:01
problem solved. bad ignition coil. thanks for the suggestions!
Posted on: 2012/10/27 6:39
Not too shy to talk
From SOUTH AFRICA
Great news, I also learned something new, wil also remember the coil in future
Posted on: 2012/10/28 6:44
Did yours (with the bad coil) run fine at higher speeds? I'm working on a car today that bogs down taking off from idle, but runs good otherwise.
Posted on: 2012/10/29 1:22
