Drive shaft...U joints Replacement
From San Diego,California
I went to replace my U-joints and found no clips holding it on,Wiki says that I have the one's that can't be replaced....What do you do? Is there a way to replace them?
Do you junk the shaft cause the U-joints are bad?I have a shaft out of an automatic there the same length, can I use that one? Any help would be appreciated.
Posted on: 2012/10/29 4:46
Re: Drive shaft...U joints Replacement
Wiki says you can buy special U-joints for non-replaceable driveshaft..
That's what the car manufacturers recommend.
Only the 63-series 5-speed driveshaft is same length as the automatic driveshaft. All 4-speeds and most 5-speeds are a different length than automatic.
Posted on: 2012/10/29 4:57
From vic
Posted on: 2012/10/29 4:58
How do I remove the U-joint that is crimped in ,it has no C clips?
Posted on: 2012/10/29 7:03
Ask the company that sells the U-joints, they have instructions.
Posted on: 2012/10/29 7:19
Looks like a pain in the ass but I'll give it a try .
Posted on: 2012/10/29 7:22
From vic
Posted on: 2012/10/29 7:25
Just watch the vidio series on You Tube. Very good demo ! Always wondered how it was done. Thanks a12datto120y !
Posted on: 2012/10/29 11:09
SWEET Video very helpful.
Posted on: 2012/10/30 5:57
