Brake master pump problem
From Sri Lanka
Hi guys
i need a help what is the best method to troubleshot master
pump it is not pressuring oil out to the rear brake when i put brake oil to it and pump it manually and feel from under the finger does suck inside it rather than pulling it out and no oil coming underneath to the main lines
thanks
regards
sumith
Posted on: 2012/10/29 6:58
Re: Brake master pump problem
Brake Master Cylinder (i've not heard it called a pump)
If it is a new Master, or a rebuilt Master you are installing, you must bleed the Master before you bleed the wheel cylinders. Otherwise it may not pressurize the lines.
Posted on: 2012/10/29 7:21
From Sri Lanka
Hi DD
Actually it was the old one that i used earlier also recently put new rubber washer kit, now it is just pressuring and deliver oil for the 1 st outlet(this is just the 1st one which colser to the steering wheel side )is it master cylinder ? i am not getting oil coming out of the other one
i bleeded the pump also several times, yet no good i am only getting oil to the rear not to the front
thanks
regards
sumith
Posted on: 2012/10/29 7:50
From Sri Lanka
hi DD
According to my master ceyinder naming on tokico master pump,
i am getting oil to the front (F marked on the Master Cylinder) and not getting oil to the Rear (R)
thanks
regards
sumith
Posted on: 2012/10/29 7:59
Yes, a very common problem. Take it back apart and carefully re-do the parts order. Anything in the wrong place, seal turned backwards or check valve in reverse can cause this symptom.
Then bleed the master cylinder BEFORE you install it. Make sure both ports are delivering pressure.
Posted on: 2012/10/29 18:02
From Sri Lanka
Hi DD
ok i will post a clear pics on how those washers are put
thanks
regards
sumith
Posted on: 2012/10/30 3:59
Master Cylinder kills me
From Sri Lanka
Hi Guys
I have major issue with my master cylinder and it is only pressurizing the front and no pressure to the rear wheels ,
I have installed new washer kit also yet the same problem
just see have i done mistake on the installation of rubber washer ?
and few more questions
Can i use b310 13/16 pump directly to my b210
if i buy a new master cylinder with booster can i get a vacuum input to it with my A12S engine ?
for clear pic please refer
http://imageshack.us/photo/my-images/515/04112012071.jpg/
thanks
regards
sumith
jpg  04112012071--11.jpg (74.82 KB)
10994_509742f388f15.jpg 640X480 px
Posted on: 2012/11/5 4:39
