wanted - bluebird disc over drum backing plates
From Melbourne, Australia
gday, i need a set of backing plates for a bluebird disc over drum setup, anybody have some by chance?
need to not be cracked, as at least one i have is
i will pay $50 plus post or otherwise ask what you want for them?
Posted on: 2012/11/3 10:26
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: wanted - bluebird disc over drum backing plates
Which year bluebird do they come from, is it only the TRXs?
Posted on: 2012/11/3 19:50
From Armidale N.S.W
Can you clarify what you mean by backing plate ? i have 2 things pictured in my mind or maybe im just getting things mixed up. Upload a pic put my mind at ease and end result is i may be able to help.
Posted on: 2012/11/3 21:38
73 1200 wagon SOLD
cool, they are pretty easy to spot as they have the caliper mounting flange and the flat face with metal plates for the drum pads to sit against
edit - DD they came on all TRX's but also on all bluebirds that were beyond a certain point, could be series 2 + 3 or just 3 im not sure
Posted on: 2012/11/4 4:03
1200 Coupe Rallycar
Mike you mean caliper brackets?
Does this setup fit 13 inch steelies or usually 14s only
Posted on: 2012/11/4 4:22
wont fit 13" alloys, 14 min, i haven't bothered with steel
i guess they are caliper mounting brackets, but also backing plates, due to dual usage
Posted on: 2012/11/4 4:32
1200 Coupe Rallycar
From Armidale N.S.W
Pretty sure i have only got two for the same side as the Ca wagon had the wrong one on one side which mucked up my spares. Another thing to beware of is there are 2 types we worked that out when we went to change pads they didnt line up on one side. Not sure if its a brand thing or a year model thing ?. Which side do you need the most ? We will check what we have and get back to you with pics as well.
Posted on: 2012/11/4 6:54
73 1200 wagon SOLD
Definitely need passenger, will check drivers
Posted on: 2012/11/4 11:18
1200 Coupe Rallycar
