OEM engines in 1200
Does anyone know if they used any other A series engine in a 1200? Either road or competition but has to be of period IE used when b110 was in production. It doesn’t matter what country it was in any links printed info would be fantastic.
Posted on: 2012/11/5 8:20
Re: OEM engines in 1200
Yes, FIA homologation was for the A12GX high-comp twin-carb engine.
Although not an A-series, they raced L16 engine in the B110, and sold them with L14. See PB110.
Posted on: 2012/11/5 8:23
thanks for that,
Do you know if there was ever an A14 used?
reason for looking for this info is i'm making plans to build a race car but i need to keep it in with regulations but want to be able to get the biggest engine i can in it but keeping it under 1500cc and try and keep the weight down. The engine can be anything as long as it was used at time of manufacture but can be road/production or an actual race car.
So far i know they used
A12, L14 and L28(samuri race in UK)
Posted on: 2012/11/5 9:46
A14 came out in 1974, after 1200 production in Japan ended.
The B140 of 1982 was a 1200 with A14 engine added. The sedan/coupe 1200 made until 1975 in South Africa, but only A12 as far as I've heard.
Super Samuri 240Z used L28
Posted on: 2012/11/5 10:07
there was a Sukati samuri 1200's built in UK they competed at silverstone and one was clocked at little over 160mph :O these were build by Spike Anderson who created the others(this car was reshelled after the accident and now owned by a friend of mine) and it has a L28 Will upload some pics
I'll dig out pics of friends car too
so really i'm looking at either using the L14 or keeping with a A12, Anyone got the specs for the tomei cars?
Posted on: 2012/11/5 10:52
Edited by Ant-Dat on 2012/11/5 11:23:28
why use the L14 when you can use an A14, although gbox is alittle stronger, the a14 would work just as effectively plus there is little to no engine mount mods depending if you have the right xmember and engine mount combo.
Posted on: 2012/11/5 11:03
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
These are old picture and car has been fully restored.
Posted on: 2012/11/5 11:05
thats my point i want to use A14 but unless i can find it was used during production then i cant due to regulations.
This car is going to compete so regulates have to be met
Posted on: 2012/11/5 11:07
regs state
ENGINE:
5.7.1. The engine cylinder head and block must be based on the normal production parts and materials as used when the car was manufactured. In the event that an exact original item is unavailable, an alternative block from the same manufacturer may be used, provided that the Eligibility Scrutineer and Competition Secretary are satisfied as to the necessity of the change.
5.7.2. Engines may be rebored up to a maximum of + 0.060" without changing class even if the capacity exceeds the upper limit by the rebore. Where a competitor wishes to exceed the permitted overbore of +0.060" and this raises the engine's capacity above the class limit, the car will be included in the higher capacity class. Stroke must remain standard, and the crankshaft and associated connecting rods material is free. Multivalve cylinder heads are not permitted unless originally fitted as standard. Engine disposition and location must remain as standard and therefore no modifications to the base structure or chassis are allowed.
5.7.3. Stroker engines are not allowed.
5.7.4. Oil lubrication system free. Dry sump systems are permitted.
5.7.5. Water cooling system free.
5.7.6. Induction system:
5.7.6.1. Manifolds and carburetors are free.
5.7.6.2. Superchargers and turbochargers are only permitted if fitted as a standard factory item in period. In this case the engine capacity will be multiplied by a factor of 1.7 to give the capacity of the supercharged or turbocharged engine. Only the original type and size of turbo/super charger may be used, and only the original period method of boost control will be permitted. The Eligibility Scrutineer will measure and seal any such installation if felt necessary.
plan on having a chat with the Scrutineer and Competition Secretary to see if i can in fact use a A14
Posted on: 2012/11/5 11:20
How about the rotary Nissan KB110? I know at least one was made!
Posted on: 2012/11/5 19:53
