PB110
From Datsun 1200 Club
Category: PB110
The Datsun PB110 model line was added March 1971 and was named the Sunny Excellent 1400 (サニー エケセレント 1400). It featured a larger overhead cam engine and modified front sheet metal styling. It is also called the "Sunny Long-nose" (サニー ロング ノーズ) because — although engine bay seems to be the same size as a B110 — the guards and bonnet of the PB110 are longer in the front to make the car feel bigger. The wheelbase is 40mm longer (less than 2 inches) but the PB110 overall is more than 5 inches longer. Most components of the PB110 are the same as B110, including 12" tires and same dashboards.
28953.jpgbrochure
Our beloved "Datsun 1200" is Nissan body code B110, equipped with the 1200cc A12 pushrod engine. This is also known as the Datsun Sunny 1200. In Japan however, there was an upscale derivative of the B110, the Sunny Excellent — body code PB110. The P apparently stands for "bigger engine". Yes, the Excellent was fitted with the L-series Overhead Cam (OHC) engine, the same type of engine fitted to the bigger Datsun vehicles.
26406.jpgAlbum 26406 11439.jpgbrochure
Sunny Excellent PB110 was offered in two body styles:
* Coupe
* 4-door Sedan
* There were no Excellent 2-dr sedans, wagons or pickups
18749.jpgAlbum 18749 18750.jpgAlbum 18750
PB110 has Unique front, but same rear except taillights & badges
174_65af5a8fe6b80.jpgPost 498207 174_65af5aa1df34f.jpgPost 498207
Notice the unique grille. The hood and fenders are also slightly modified in the front area (see Differences section below).
10316.jpgAlbum 10316 13469.jpgAlbum 13469
This factory brochure shows both vehicles (Comparo)
Sunny 1200 (left) and Sunny Excellent 1400 (right)
154.jpgbrochure
Features
* L14 Engine, 1400cc
  * Single-carb version: 85hp, 11.8kgm/3 torque @3,600 rpm
  * Twin-carb version (GX): 95hp, 12.2kgm/3 torque @4,000 rpm
* Top Speed (both engines): 155km/h
* 4-speed floor shift
* optional Nissan Full Automatic 3-speed floor shift
  not available with GX models
Sunny 1400 - The writing before 1400 says "Coupe" (Kūpe)
Album.jpgbrochure
Sunny Excellent 1400 brochure - Closeup of grille. The extended forward "peak" of the Excellent grille is evident here, compared to the more flat grille of the 1200.
741.jpgbrochure 1533.jpgAlbum 1533
Excellent GX Brochure - Notice the engine (sidedraft carbs), fancy seats, and the same-as-B110 dashboard
742.jpgbrochure
GL interior. Dash is same as PB110, but upholstery and door cards are slightly different.
174_65af5aaae95c5.jpgPost 498207
Coupe
Notice the unique tail lights. GX comes with 'blackout' rear panel
30543.jpgAlbum 30543 458.jpgbrochure
174_65ae3c1aaa8cc.jpgPost 498206
Customized
18718.jpgAlbum 18718 18717.jpgAlbum 18717
Sedan
Only a 4-door was offered in the 1400 series -- no 2-door sedans were made.
Sunny 1400 4-dr sedan with aftermarket minilite-style wheels
129.jpgAlbum 129
Trim Levels: DX, GL and GX
This outlines the various trim levels the Coupe was available in: GX, GL and DX. The writing above '1400' phonetically spells out the english word "Excellent" in japanese katakana writing: e-ku-se-re-n-to.
461.jpgbrochure
The same trim levels were offered for the Coupe and for the 4-door Sedan:
18200.jpgbrochure
* GL and GX trim used wood grain on lower half of dash
* 1972 Facelift dash has hooded gauges. The hood reduces glare.
  (NOTE: this is the same dashboard as in regular 1972 Datsun 1200s)
* Excellents came with extended color choices for carpeting
GX
Dash is same as 1200
1972 facelift GX (same as JDM 1200) | 1971 GX (same as 1200)
460.jpgAlbum 460 11440.jpgBrochure
  • 3-spoke standard GX steering wheel
striped seat fabric (brown or black/blue)
11438.jpgBrochure
GX Console#PB110 with clock or OPTION w/gauges
7712.jpgAlbum 7712
Fog Lamps standard on GX
174_5d50d8fdde600.jpgPost 492213
Same as 1200: GX Steering Wheel, 1972 Facelift Dash with hooded guages
Unique to 1400: Console w/clock. Cloth-insert PB110 seats.
456.jpgbrochure
GX features:
174_65af587e75b98.jpgPost 498207
GX mirror & GX hubcaps
174_5c5d516a6030a.jpgBrochure 22363.jpgAlbum 22363
GX rear PB110_Badges#Trunk_Lid & black taillights
174_5d50d91f471e7.jpgPost 492213 174_5d586a56f1a8d.jpgPost 492292
DX
1972 DX interior -- same dash & steering wheel as B110 DX
10317.jpgAlbum 10317
DX console with MASK 'Sunny' clock blank
3099.jpgAlbum 3099
Features
Grille#PB110
Badges
Lights
Wheel and Tire
As with all B110, the PB110 Excellent used 12" tires.
The Excellent had unique wheel covers, which are different from the B110 wheel covers although still 12" in diameter.
1971 options:
7715.jpgAlbum 7715
  1. GX wheel cover on blackwall tyre
  2. GX wheel cover on dual-stripe whitewall
  3. GL wheel cover on wide-stripe whitewall
GX hupcap
6943.jpgAlbum 6943
29586.jpgAlbum 29586
Optional Equipment
Engine
The Sunny Excellent PB110 was fitted with 1400cc L14 engine, a smaller-displacement version of the L16 fitted to the Datsun 1600. This is an overhead cam engine. Both a single carb and dual-carb engine was available. Top speed was 155kmh, up 5km from the Datsun 1200.
Under the bonnet of this Excellent is the rotary engine prototype used to advance the development of NISSAN's new rotary.
Interior
1971 Excellent GX has the same #dashboard as 1971 B110 GL, with woodgrain trim
11440.jpgAlbum 11440
1972 (Facelift) Excellent 4-dr sedan Interior with the standard 1972 JDM B110 #dashboard
852.jpgAlbum 852
Notice the upmarket seats, the (aftermarket) steering wheel, and 1972 dashboard
PB110 had unique #consoles, door cards and #seats
30520.jpgAlbum 30520
Consoles
Sunny Excellent used consoles the similar to B110, but extend up further and back further with different gauge options.
Seats
Another way the Excellent was differiented from the 1200 was with upscale seats materials.
* Deluxe: Vinyl seats like B110, but with fancier form-fitted stitching
* GL: Tricot cloth (single color)
* GX: Fancy striped Cloth-insert vinyl seats
1971 Seat Upholstery Choices
7724.jpgbrochure
GX
* brown striped cloth
  for #009 Orange, #004 Green, #821 White
* black striped cloth
  with exterior Colors #008 Blue, #005 Blue, #931 Gold, #930 Green, #665 Yellow
GL
* black tricot
  for #009 Orange, #005 Blue, #004 Green, #931 Gold, #930 Green (Coupe only), #665 Yellow
* blue tricot
  for #008 Blue, #821 White
Deluxe
* black vinyl leather (for #008 Blue, #930 Green (Coupe only))
* yellow vinyl leather (for #931 Gold, #821 White, #665 Yellow)
GX seats options - Brown-striped cloth or Black-striped cloth
23413.jpgbrochure
GX seats (brown striped cloth)
11438.jpgBrochure
Dashboard And Steering Wheel
1971 | 1972
2129.jpgAlbum 2129 460.jpgbrochure
* Early GX dash (same style as B110, but with woodgrain accents)
* Three-spoke GX wheel, spokes have single slots
* Deluxe uses same steering wheel as Standard B110
* GL uses 3-spoke steering wheel
* GX has standard 3-spoke 'large-horn button' wheel with "GX" emblem in center
  Each spoke has two long slots.
The Late PB110 instrument cluster is the same as Datsun 1200 "Late", but the dashpad is different as is the glovebox:
B110 vs PB110 Late Dash Comparo
13480.jpgAlbum 13480
3099.jpgAlbum 3099 11130.jpgAlbum 11130
Later 'hooded' dash. Picture clearly shows the concave profile of the instrument cluster. (aftermarket seat color, shift knob, equalizer). Judging by the wood-grain dash and steering wheel style, this is a GL model.
Details:
13214.jpgAlbum 13214 13454.jpgAlbum 13454 13452.jpgAlbum 13452
How Different From B110
How different is the PB110 from B110?
Same:
* Passenger compartment
  * Doors
  * Roof
* Firewall
* Rear quarters & boot lid
Different:
* Front fenders incorporate corner lamps
* Wheelbase +40 mm
* Radiator Core Support appears to be only +40 mm forward
* Bonnet is longer, extended further beyond core support
Discussion: POST PB110 (Sunny Excellent) vs. B110 (Sunny)
So the engine does not appear to be farther forward, but actually as far back as in B110. Being "set back" a little compared to the front wheels may have contributed to good handling even though the L14 engine is much heavier than A12 engine. The extra 40 mm is probably used for the slight length difference of the L14 and the extra thickness of the 510-type radiator.
In front of the radiator core support and bonnet sticks out about 5 inches longer than B110. 40mm in the wheelbase, and 130mm in the nose.
174_580aee57e262a.jpgPost 482037
The extra length is all forward of the windshield:
18751.jpgAlbum 18751
Fenders appear to be same length & height, but 1400 wheel arch is slightly larger and doesn't go as far forward.
1400
26127.jpgAlbum 26127
1200
26130.jpgAlbum 26130
Fenders use corner lamps
26126.jpgAlbum 26126 26129.jpgAlbum 26129 26128.jpgAlbum 26128
Front Apron panel
1200 Apron
22521.jpgAlbum 22521
1200: License plate bolts to bumper
1400: License plate bolts to apron
1400 Apron 62610-H2500 (Sedan & Coupe)
174_65af5a08757a1.jpgPost 498207 174_65af5a101e34e.jpgPost 498207
174_65af5a16be02e.jpgPost 498207
174_65af58f4f1251.jpgPost 498207
Racing
The racing PB110s included this Coupe (KPB110) with the Nissan works competition LZ engine LZ14 DOHC four-valve engine:
KPB110 #2 with LZ14 Engine
17296.jpgAlbum 17296 17297.jpgAlbum 17297
* LZ14 May 3, 1973 introduction for TS-a Class japan Grand Prix racing
* 16 Valve Twin-cam head on L-series block, 1600cc
* 200 HP @ 9,400 RPM
Takamiti Shinohara (篠原 孝道) rented LZ14 for the semi-Works Omori team for "1973 Japan Grand Prix" — if I translate correctly Wikipedia Japan article
Sunny 1400 Coupe race car at Advan Historics
4627.jpgAlbum 4627
Brochures and Advertising
Japan document showing the Datsun brand was used for the Sunny Excellent (notice first line "Datsun Sunny"):
174_5c60ac816a9f9.jpgPost 490544
Also See
Also see:
* PB110 Colors
* PB110 Engine
* PB110 Parts Donor
* PB110 Suspension
Custom
PB110 coupe with KB110 grille and bumper
12526_4fc7fc61975dd.jpgPost 408282
Photo Album Index
Photo Features
See detailed photos of PB110 cars.
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=PB110"
This page has been accessed 167,418 times. This page was last modified 05:58, 1 September 2025. Content is available under Datsun 1200 Club.
