Cheap Mods Datsun 1200 Sedan
Not too shy to talk
From Portugal
I just started a new car project with a Datsun 1200 Sedan... Since I'm student and not really a very rich person, the other day I was searching for some cheap mods i could do with the Datsun (Engine or just cool visual Modifications), i came up with some simple and cheap ideas that will certainly do in my 1200, for example:
I'll remove the Datsun symbol and paint the grid, to be identical to this one, and probably put the Hood Matte Black:
Which other cheap and easy modifications (Visual or mechanial) would you consider doing on your Datsun 1200 Sedan?
By the way, here is the picture of the car (White one):
Posted on: 2012/11/12 13:52
Re: Cheap Mods Datsun 1200 Sedan
depends what you want to spend, a 120y sway bar could improve handling, std aus sway bar is 17mm and 120y 20mm.
A downdraft weber? 1 3/4 -2 inch exhaust, extractors, oval port head.
Skys the limit with what body mods you want to do, all depends on your skills and time i suppose.
Posted on: 2012/11/12 21:38
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Lowering is inexpensive. Fronts can be done for zero cost, rears only need 2" lowering blocks. This improves handling and reduces aerodynamic drag. The downside is it will make the ride harsher over bumps.
Posted on: 2012/11/12 21:56
Not too shy to talk
From SOUTH AFRICA
I personally like to remove the fan and replace it with an electric fan. Every little bit helps !!!
Posted on: 2012/11/13 19:59
