Need Advice on Head
From Sri Lanka
Hi Guys
I have problematic Spark Plug thread ,which the spark plug doesn't fit properly tight enough on my second piston head, What do you advice ?
Can i make oversize spark plug on all cylinders ?
or is it good to fill the problematic spark hole and cut it's thread back to the normal specification ?
thanks
regards
sumith
Posted on: 2012/11/21 4:13
Re: Need Advice on Head
If a spark plug thread is stripped, we use Heli-coil. Basically new thread is cut with an oversize tap, then the heli-coil insert screwed in, then the spark plug will screw in. Do not overtighten.
Only the damaged thread needs repair. There is no need for the other cylinders to match.
I have not heard of oversize spark plugs.
Posted on: 2012/11/21 6:12
From Sri Lanka
Hi DD
thanks, something new to me helicoil but got an idea
i will talk to the engineering worker
thanks
regards
sumith
Posted on: 2012/11/21 6:34
