Help needed - spiggot bearing
From Canberra Australia
Hi
I am in Australia and have an A14 motor and the spiggot bearing is about 17mm OD and 12MM ID. This is larger outside diameter than an A12. I do not know the model of car the A14 came from.
Can anyone help me with a part number for this size spiggot bearing or a suggection as to which model car its likely from.
Regards
Posted on: 2012/11/21 9:15
Re: Help needed - spiggot bearing
From Armidale N.S.W
Just go and see repco and ask for 79 model datsun sunny wagon manual spigot bush specify its the A14 4 speed model. Although you will most likely find that all A series engines A12,A14,A15 use the same spigot bush.
Posted on: 2012/11/21 9:27
73 1200 wagon SOLD
Nissan part number: 32202-18000 BUSHING-pilot
It fits all A-series A10/A12/A13/A14/A15/A12A, including Cherry E10 fwd model.
Dimensions:
* O.D.: 0.671" (17.0 mm)
* Width: 0.723" (18.4 mm)
* Bore: 0.48" (12.2 mm)
Posted on: 2012/11/21 9:42
Edited by ddgonzal on 2012/11/21 10:07:43
I know l series is same as RB and ca spigot. Nissan have then for $5 each..... Get 2 so you can hydraulic lock the old one out.
Posted on: 2012/11/21 13:00
From Sydney
I have some new ones available if you are in need of one..
http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=57701
Posted on: 2012/11/22 0:30
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
