Is this Carburation or Tuneup problem ?
From Sri Lanka
Hi Guys
I got a problem with my b310,since few weeks ago it used to overflow the
carburetor time to time, and then i removed the carb and found that main jet was
detached from the thread and fallen down the carb,and then i bought a same size jet
and installed it back did not go for a big tune up since it is same size,
but now car is giving trouble it start once but stumbple and die till the engine is warmed up
when the engine is warmed it doesn't die but stumble on sudden acceleration,but can accelerate
smoothly, and also there is sudden buff sound in higher rpm too, and also car doesn't die
after key off , it takes 2 more seconds with buff sound is it carburation problem or just a tuneup is enough ?
look these video
http://youtu.be/INWY2dlGyOc
http://youtu.be/JO9C1QUaR8g
thanks
regards
sumith
Posted on: 2012/12/10 4:37
Re: Is this Carburation or Tuneup problem ?
Tune-up includes carburetor adjustments.
Posted on: 2012/12/10 5:34
After watching the video, I think the problem could be normal tune-up adjustment of the carb OR it cou
ld be other carburetor problem. such as er loose internal part
So start with the most basic setting - inspect the float level, then do the tune-up carburetor adjustments. Too fast an idle can cause engine to run-on and not stop immediately
What does "buff" sound mean?
Posted on: 2012/12/10 5:44
Edited by ddgonzal on 2012/12/10 6:00:08
From Sri Lanka
Hi DD
It looks having a missfire on higher rpm, and they is sound rhymes it self "buff", i checked the float level that is perfect.i will check it again back to see what went wrong with it in the week end
thanks
regards
sumith
Posted on: 2012/12/10 6:17
From Sri Lanka
Hi Guys
Something to be clarfied, when You stand infront the carb the fuel glass is the right side main jet is primary or secondary ?
thanks
regards
sumith
Posted on: 2012/12/10 11:55
The primary is the smaller side
Posted on: 2012/12/10 19:07
