« 1 2 3 (4) 5 »
Re: A15ETT - inspiration to do a rebuild/rebirth
From Melbourne, Australia
the mustard machine has some good gear in it already
would maybe be better to put this in green coupe, i would have to rip the air con out of the mustard one for turbo and intercooler space
i love the celica box (have one behind this motor and have one in rally car, but i get confused which model the box is) shifts great, takes the abuse, fits the tunnel and isn't overly heavy.
i just bought a couple of second hand dellow conversions at different times when they came up for sale
h165 is pretty tuff, i would be happy with one behind this. But i don't do stupid burnouts like roll backs and standstills etc
another a15ett vid linky
Posted on: 2012/12/13 10:54
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
a bw 68 will take the abuse too.
Mustard is a good car, almost too good to bastardise. put them in club permits Mic much better
Posted on: 2012/12/13 10:59
Nice vid, the turbos sound awesome!
The green coupe is that the spare shell?? I thought that was bare, lots of work to get it going if so!
The old man has a supercharged fuel injected a14 but havent found a box for it as yet, did consider purchasing a 60 a close ratio but we're just not convinced it will stand up to the forced induction. Otherwise i would say a 63a box, but theyre rare as hens teeth now...
Ill have to look into a dellow conversion, any hints on sellers/producers?
My h165 has an awful wine to it, ive done 2 seals in either side where the bearings are. Have checked oil seems to be all good. Seems like a decent diff otherwise certainly well suited to the lightweight tail happy ute :P haha
Posted on: 2012/12/13 11:06
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
only takes a weekend to assemble a 1200 if you have the bits, its a rolling shell with skyline struts and a h145 in it atm and steering etc is all there
60a is pretty tuff if in good condition from the beginning
the diffs will run for years with a whine, it's just annoying
just cruise around for a second hand celica kit, they come up for sale every now and then
best thing i did to that ute was put coupe leafs in... and weld the diff centre. i just found that dif centre the other day coincidentally
Posted on: 2012/12/13 11:19
1200 Coupe Rallycar
any pics of sc efi a14?
A14ZE
Posted on: 2012/12/13 11:20
1200 Coupe Rallycar
well after god knows how long trying to upload a damn picture, i cant. lol
So yes i have a pic, and no i cannot share it haha
60a sounds like a nice box behind carbs, wouldnt risk spending good money on it with the chance it will fry on forced induction. Especially not when you could pay a little more for whats possibly a bullet proof box.
Ive heard of someone putting a K box behind a series? dont know how that works...
Why coupe leafs?
Am considering welding the diff up, but i dont want to write the ute off when the first wet day comes. Perhaps i should get a nice big open bit of ground to test it out a bit and see what it does...
Posted on: 2012/12/13 11:56
1200 Ute - Mild A12
i wouldn't put a welded diff in a road car, i only did that when i was using the ute for autocross. It gave a hell of a lot more control, so i would actually say it's safer in the wet to a decent driver
the ute springs are designed for a 500kg load in the tray, therefore are a lot stiffer than necessary, therefore less traction. coupe springs worked well for me, some say if you take the extra leaf off the ute that makes it the same, though i would love to see that proven by actually testing of spring constants as i am suspicious it may not be true.
Posted on: 2012/12/13 21:18
1200 Coupe Rallycar
Ute leafs are totally different, even after the largest leaves are removed.
* 4 leaf: 2 x 6mm thick, 1 x 7mm thick, 1 x 13mm thick
* 5 leaf: 2 x 6mm thick, 1 x 7mm thick, 2 x 10mm thick
Sedan and Coupe have the same Leaf Springs assembly - same part number and same spring constant
* 55020-H1000 Sedan, Coupe
* 3 leaf: 1 x 6mm thick, 2 x 7mm thick
Posted on: 2012/12/13 21:35
Yeah right, that makes heaps more sense! I tried the 2 inch blocks, and quite frankly i was less than impressed. Made the whole ride even worse, hitting bump stops when driving the slightest bit fast around corners with uneven road. It was just very rugged and 'jumpy' to drive in the rear.
Ill have to find me some coupe springs then ey!
Posted on: 2012/12/13 23:15
1200 Ute - Mild A12
From Townsville, Qld
did you ever investigate the prospect of doing a draw through setup? I know the throttle would be a pain but think about how much less piping you'de need to clutter the whole lot up
Posted on: 2012/12/29 16:42
« 1 2 3 (4) 5 »
