valve guide seals
From Christchurch NZ
Is th ere any real advantage in useing the more expensive valve guide seals over the much cheaper rubber umbrella ones.
Posted on: 2004/4/19 11:26
Forced Induction!
Re: valve guide seals
From Auckland N.Z
probably last longer.
Posted on: 2004/4/19 13:21
From Millgrove Vic OZ
None if guides or stems are worn otherwise teflon seals are the go.
Posted on: 2004/4/19 15:14
Cheers Feral
Umbrella seals last far longer than ring-type seals. As the guides wear, the umbrellas still keep oil from running down the guides.
Posted on: 2004/4/19 17:33
Yeah I thought as much. The clever ones are killer dear by comparison.
Once again cheaper wins.
Posted on: 2004/4/19 22:00
Forced Induction!
