Strange problem with the starter
From Sri Lanka
Hi guys
I can't start my car since the starter motor does not work there is a clicking sound on a relay ut starter doesn't work, so i took it away and gave it voltage and it worked solenid and motor both but cranking was slower than usual.
then again fixed it the car and it worked 2 or three times and then again doesn't work , so i removed it again and gave 12 V supply from outside and it worked well again ,what sort of a problem is this ? this is strange to me
thanks
regards
sumith
Posted on: 2012/12/17 20:42
Re: Strange problem with the starter
Could it be your battery doesn't hold enough cranking Amps ?
Posted on: 2012/12/17 20:47
Very common problem. This occurred with my wife's 2-year old car.
Most common cause is the battery cables need to be cleaned. See Battery Maintenance. Less common reasons include worn out battery, or worn out starter.
Posted on: 2012/12/17 21:45
From Sri Lanka
Hi DD
I guess it can't be battery because when i take the motor out and gave a direct supply to check then it worked fine and my battery was in very good condition,i doubt whether motor doesn't work with the load of (when rotating with the flywheel)is it possible a motor runs without load and not working with load ?
if the main supply is the matter it atleast solenid should work is it ?
checked the voltage at the solenid signal wire and it is having
thanks
regards
sumith
Posted on: 2012/12/18 0:49
Yes, exactly. All occurs just like you say when the battery connections need cleaning.
It should only take 15 minutes.
Posted on: 2012/12/18 0:55
From Sri Lanka
Hi dd
I got it done ,Actualy it was a bad earth connection,installed a new set of earth and power wires and problem sorted
thanks
regards
sumith
Posted on: 2012/12/18 10:04
Bad earths, pain in the behind in our cars... ,so annoying
Posted on: 2012/12/18 10:08
Yay! Another Datsun returns to the road.
Posted on: 2012/12/19 0:41
From Sri Lanka
Hi Guys
So Annoyingly i got the same problem again,so Suspected bad battery and gave it to recharge it ,they said battery power has gone down and need to recharge it to see whether it can hold power , it was perfect till the last moment after 10 days of car just lying without running i could crank the engine enough times without any problem.
tell me a easy way to see whether the battery is discharging itself while car is not running
And about the Ignition coil resister : -
Is it getting extremely hot while car ignition is on ? is it hot while car engine is running ?
thanks
regards
sumith
Posted on: 2012/12/20 3:37
Have you cleaned the battery terminals yet?
Posted on: 2012/12/20 3:50
