WTD MELB: sunny/stanza or 1200 disc struts, clutch pedal/manual pedal box
Hi All,
Was wondering if anyone is wrecking a 1200 and has the lines for a dual system.
Also after struts with discs (Stanza, sunny or 1200) and pedals for a manual conversion.
Cheers!
Posted on: 2012/12/28 5:42
Re: WTD MELB: sunny/stanza or 1200 disc struts, clutch pedal/manual pedal box
From Armidale N.S.W
Got complete sunny struts here but no steering arms or anything to adapt them up you'd have to source that elsewhere and ive got a clutch pedal and brake pedal to convert to manual. You dont actually have to change the whole pedal box there the same you just change the pedals the clutch pedal is replaced in autos with what i would call the guts of a clutch pedal. If you want i can sell you the whole pedal box but up to you. Should you choose to buy from me. Cheers Andrew
Posted on: 2012/12/28 7:32
73 1200 wagon SOLD
Hi Andrew,
Spewing you are in NSW, makes getting the struts a bit tricky. What would you be chasing for the guts of the pedals? Also would you post them to me I'd pay for postage of course.
Regards,
Richard
Posted on: 2012/12/28 7:48
From Armidale N.S.W
$50 including post for the pedals with bushes washers and long shanked bolt and nut that holds it all in and together. Struts wouldnt cost a real lot to ship i would use E-go probably around $50 tops and the struts are worth about $80 the pair. Cheers Andrew
Posted on: 2012/12/28 8:05
73 1200 wagon SOLD
From Melbourne, Aus.
Posted on: 2012/12/29 6:24
Edited by crumb on 2015/1/22 21:52:57
I got yeh complete front end from a coupe if u want. Shoot me a offer
Just surface rust
Located in oakleigh
Posted on: 2012/12/29 10:31
PM's sent... as it would be easier for me if I can source them locally.
Andrew I'll let you know if one of these Melbourne guys falls through and will let you know about the pedals.
Cheers,
Richard
Posted on: 2012/12/29 22:37
