120y caster rod mounts
From penrith,sydney,aus
im picking up another 120y next week, ive half put the struts back in it butr the steering rods from the struts dont fit into the draglink the pin is to big any one know something or have some standard 120y steering stuff
also i need a pic of where the caster rods mount at the front of the car, pretty sure its missing the brackets its meant to mount onto, ive searched and searched so if someone could send me a pic it would be great
Posted on: 2013/1/4 6:25
2 door 1200 sedan project l20b stroker
Re: 120y caster rod mounts
There are early 120Y and late 120Y suspension.
Posted on: 2013/1/4 7:04
Here ya go:
Posted on: 2013/1/4 7:23
The tie-rods go between the Steering Arms and the Draglink. The steering arms differ between early and Late 120Y, but they take the same tie-rod ends and both use the same drag link.
Could the struts or the tie-rods not actually be 120Y parts?
Posted on: 2013/1/4 7:39
From Sydney Australia
Castor rods are from the Lower Control arm forward to the mounts on the Body,Steering arms bolt to the bottom of the struts,Between the steering arms and the drag link are the outer steering rods with screw on or in steering joints both inner and outer.
It appears your thread Title is wrong or your understanding of which part is what is somewhat confused,Hope this helps.
Posted on: 2013/1/6 0:33
