« 1 (2)
Re: S13 Caliper adapter plates.
From Springwood NSW, Formerly Tas.
DBA says they're 280mm fronts and 258mm rear
Posted on: 2013/1/4 23:40
1978 120y Coupe.
258mm is also the size of 280ZX rear discs (non-turbo).
ddgonzal what are the 258mm brakes?
What is the bolt spacing on the S13 caliper?
The B110/B210 caliper spacing is 84mm
This one is for using 258 mm disc rotors
Posted on: 2013/1/4 23:46
From Trinidad and tobago
i have a set of s13 disc and there 10'' which is 254mm from the front.
here are the brackets.
Posted on: 2013/1/5 0:19
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
S13 came with three different rotor sizes:
* 252mm diameter Front Non-ABS
* 257mm diameter Front 4-Wheel ABS
* 258mm diameter Rear
See S13 Brakes
Posted on: 2013/1/5 0:41
From Armidale N.S.W
S13 SR20DET front are 280mm i have a set here.
Posted on: 2013/1/5 3:46
73 1200 wagon SOLD
Correction: S13 come in at least FOUR different rotor sizes.
Posted on: 2013/1/5 4:03
still after a set, i got the calipers with 100mm centers and rotors i got are the 250mm
Posted on: 2013/5/2 7:13
1978 120y Coupe.
From Sydney
I have a 1 set left if needed. They are the ones pictured above in reply #13
Posted on: 2013/5/2 7:43
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Cool as pm'd
Sorry this turned into a wanted thread, I'm just keen to get these on.
Posted on: 2013/5/2 13:11
1978 120y Coupe.
« 1 (2)
