« 1 ... 28 29 30 (31) 32 33 34 ... 49 »
Re: Datsun 1200 sedan project..
From Trinidad and tobago
Damn!!
I forgot to put up some pics of the brake conversion that i have been doing.There s13 250mm rotors with nissan calipers and i made up a custom bracket from 1/4'' ply so i have th eget the metal shaped an holes drilled.But it has very good clearance of the rotors an enough pads holding on the disc..here are some pics
The new stoppers will be finished soon.
Posted on: 2013/1/11 2:23
Edited by darrenwilson on 2013/2/8 22:52:26
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Leave it ply wood and only drive it in the dry Weather joking
Good work
Did you test fit your 13 inch rim over the top?
Posted on: 2013/1/11 2:28
Yes But now i'm still waiting on the guy to get the other side caliper for me,to get the brackets make so i could get them mounted up and test drive.
Posted on: 2013/1/24 2:37
Street Sleeper!
ok so here i have the other caliper to almost complete my brake setup.I have also got the caliper bracket made.
Here you could see where i have filed down the caliper to get enough clarence in the rim.
Posted on: 2013/2/8 23:29
Street Sleeper!
Ok back to it again.We have made some mods to the caliper an shaped the bracket to sit down nice.Also cleaned them up an hopefully tomorrow i will have the car back on the ground wit the set up all finished.
Posted on: 2013/2/16 4:45
Street Sleeper!
Posted on: 2013/2/16 16:32
Street Sleeper!
Wow,Its a while since i've been on here but my 1200 is ok for the while i have baught a new a15 cabby and hot coil to put on the a15 engine that i have still to put in .
well here are some pics.
Posted on: 2013/3/10 2:48
Street Sleeper!
On the road a few times an i took a few shots!
Posted on: 2013/3/10 2:56
Street Sleeper!
From Snohomish, WA USA
Nice looking ride. How does that new stock carby run?
Posted on: 2013/3/10 15:16
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Thanks!I haven't tried it yet still running the a12 one.but i hope it works good.
Posted on: 2013/3/11 1:19
Street Sleeper!
