top gear switch on late 56A 4 speed box
From Fremantle, West Australia
When you change out a gearbox with the top gear switch for one without,
are you meant to short the two wires or insulate them?
Thanks
Posted on: 2013/1/12 12:02
Re: top gear switch on late 56A 4 speed box
The wiring harness will still be intact. Do nothing with it, niether short nor insulate them.
TCVAS: If you neglect to connect the top switch, vacuum advance works normally.
Posted on: 2013/1/12 17:55
