Compression testing question
When I do compression tests I find the reading keeps climbing the more I let it crank, up to say about 1 or 2 dozen cranks. But I see instructions say to let it crank only 4 or 5 times.
I always thought you should let it crank until the psi reading stops rising, but is that wrong? Should I just let it crank over a limited number of times?
Posted on: 2013/1/17 4:15
Re: Compression testing question
Something is.wrong
Ive used many gauges, none took more than six pulses to .
Posted on: 2013/1/17 4:44
From Snohomish, WA USA
I usually count 10 times. I put the gauge in a position where I can see it between the dash and the hood and watch it go up. 10 cranks and it usually is done. Good compression on a stock A series A15 is around 140-160psi. If all cylinders are with-in 10psi then your good. Others may have something different. That's just what I have found.
Posted on: 2013/1/17 4:48
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Could be worn bore/rings or ring lands. As the engine turns over more oil is thrown around and tends to seal the cylinder better.
Squirt a teaspoon full of oil in the bore and spin the engine up for 5 seconds without the plugs in it. Then recheck the compression. If it pumps up quickly you may have an engine problem.
Posted on: 2013/1/17 9:51
