FS Series 2 bluebird electric dizzy with boost retard
From Melbourne,Australia
Now that Ive changed my setup to 4 coils my dizzy is no longer needed and is up for sale. Its a series 2 bluebird that was reco'd and had a vacuum boost retard fitted and setup buy ignition torque in Bayswater. The timing can be retarded up to 20 degree's under boost and can be adjusted with a small screw on the side of the dizzy is was also fitted with a new ignition module and has new rotor button and cap. I also have another new rotor button and cap still in the box to go with it. Suit any L series Z18 ect
After $200ono owes me twice that can also send pics on request.
Posted on: 2013/1/20 23:51
Re: FS Series 2 bluebird electric dizzy with boost retard
From Sydney
bargin I say, If by chance it doesn't sell before datnats, Im very interested, would be the business for my A-series turbo build and modify the housing to suit.
Posted on: 2013/1/21 0:11
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Yep bargain. If I were contemplating turbo id snap it up too. But I have a modded dizzy still to fit with reduced Mech advance.
Grab it Benny and just pick up at datnats.
Posted on: 2013/1/21 0:28
Can bring it with me to the nats Benny if it hasn't sold buy then. Otherwise wire me some cash and it's yours
Posted on: 2013/1/21 1:27
BUMP
Posted on: 2013/1/24 0:05
How do you generate the vacuum for the retard system?
Posted on: 2013/1/24 1:33
It has a vacuum canister on the side and is fed from the engine
Posted on: 2013/1/24 20:56
Under boost, the engine makes no vacuum. What do you connect to the boost retard side of the distributor? Does it go to to a special throttle body fitting?
Posted on: 2013/1/24 21:59
Yep go's to a fitting on the throttle
Posted on: 2013/1/24 22:29
SOLD
Posted on: 2013/2/3 10:24
