a12 crankshaft sprocket removal
Quite a regular
From neerim east victoria
how do you remove the crankshaft timing chain sprocket,is it a press fit that you need a puller to remove it or does it slide off? as I'm fitting a new timing chain and sprocket kit and want to be prepared before I start
ty Russ
Posted on: 2013/1/21 21:04
Re: a12 crankshaft sprocket removal
From Ballarat Victoria
They just slide off. You wont need any special tools.
Posted on: 2013/1/21 21:56
VIC DYNO HIRE
Quite a regular
just tried to "slide it off" but its stuck solid maybe some prick has loctited it,will have to try a puller
Posted on: 2013/1/22 5:28
I use two large screwdrivers from each side to "help" it come off.
Posted on: 2013/1/22 5:40
