Need opinions for making seat brackets
Not too shy to talk
From San Francisco Bay Area, California, USA
Hello all, I recently purchased a 72' Coupe which I have begun restoring.
Unfortunately, the previous owner(s) ripped out the rear mounting brackets for the seats.
I still have the front bracket. When the car was purchased the previous owner drilled holes in the floor pan and bolted up some Honda Civic seats with only 2 bolts.
My question is what can I do to safely and securely mount new seats in the car.
Thank you!
jpg  photo (5).JPG (121.21 KB)
16991_5101b2f46773a.jpg 640X480 px
Posted on: 2013/1/24 22:17
Re: Need opinions for making seat brackets
Go to the wreckers and cut the spot-welds that hold in the original floor braces.
Parts A, B and C
Posted on: 2013/1/24 22:33
Not too shy to talk
Oh thank you! But I think it will be nearly impossible to find any 1200's at the wreaking yards in my area. Are there other brackets that can be made to fit? Or should I just go with making my own? I really wish the previous owners hadn't hack her up.
Posted on: 2013/1/25 2:25
1972 Datsun B110 Coupe
1992 Honda EG8 (EG9 replica)
1999 Honda EJ6 Hatchback
From Armidale N.S.W
If its a 1200 i have one here that i am cutting up for spares it still has the rear seat mounts in it. I can carefully remove the spot welds and supply you with the rear mounts if your keen and post them to you. For a reasonable price of course.
Posted on: 2013/1/25 2:33
73 1200 wagon SOLD
From NSW
i was just about to post the same question... my situation is a little different. its for a 1200 ute and i have the original mounting points as shown on ddgonzal's post, however, i have purchased some sparco seats and seat mounts. i am trying to work our the best way to install the seat mounts without too much modification... any ideas?
these are the brackets..
jpg  00490NR Steel.jpg (66.20 KB)
3190_5102125762660.jpg 775X527 px
Posted on: 2013/1/25 5:00
That's a different question: How to mount aftermarket seats vs. how to replace missing brackets.
Yes, use those sparco seat brackets, and bolt to the stock 1200 seat rails.
Posted on: 2013/1/25 5:12
From NSW
heh no need to get technical!! but thanks for the help. i thought about that but then the seat sits quite high... might have to find a was to make it work...
thanks again.
Posted on: 2013/1/25 5:18
Not too shy to talk
So in order to do something like this I would have to replace the stock brackets and find stock rails anyways?
Posted on: 2013/1/25 6:37
No you don't have to do that. Some guys just bolt a seat straight to the floor pan, for example.
If you want it legal I would suggest using the stock pieces.
Posted on: 2013/1/25 7:11
Not too shy to talk
Right. I just feel like mounting seats to the floor pan is a bit unsafe. (Previous owner did this) After all, I still have the front bracket and would like to utilize it for what it was entended for.
Thank you for the advice. I've got some thinking to do. I was hoping I could retrofit some other Nissan brackets in and find decent junkyard seats.
Posted on: 2013/1/25 7:37
