brake booster on datto ute
From yeppoon qld
ijust put in stanza struts and been trying to find out what the best booster and easiest to install behind the master cylinder.will a 120y booster fit up alright.who has done this?
Posted on: 2004/4/22 9:51
Re: brake booster on datto ute
From Sydney, Australia
If you put the word "booster" in the "Search" section to the left....you'll have enough reading to last you a few hours.
Posted on: 2004/4/22 10:10
From yeppoon qld
thanx dude
Posted on: 2004/4/22 13:58
From Melbourne,Australia
Hey mate 120y booster bolts straight on then use a 240k master and you shold have no problems
Posted on: 2004/4/23 3:02
From Toowoomba QLD
will the 120y booster and master sit in the ute as standard?? (ie just unbolt from 120y and bolt into 1200 ute). And is it really necessary??
I just removed the struts from 120y to put into my ute so I can have discs but was told with the 11/16" master cylinder that I dont need to run the booster. True or False??????
Posted on: 2004/4/23 7:22
From Maryborough, QLD, OZ
i have a 120y booster waiting to go into my ute....so if anyone knows if they are a straight fit...(no mods neccessary) that would be great!!
But from what i can see, there is a fold in the metal of the fire wall right where the spacer for the booster has to go......mine is an '84 model....were older ones any different?
Posted on: 2004/4/24 23:42
