A15 Head Bolts
From Gold Coast Queensland, Australia
I'm looking for a new set of head bolts for my A15. I live in australia and can't seem to find any. I snapped one tightening it yesterday. I used the tension settings for A15 but this motor has an A12 head and weaker bolts. I realised all too late. Am i better off getting A15 bolts and if so where from?
Posted on: 2013/1/30 6:53
Re: A15 Head Bolts
does ARP make head bolts?
Posted on: 2013/1/30 6:59
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: A15 Head Bolts
ARP does not sell head bolts
A15 uses the same bolts as later A12. Just make sure thet are the strong Cromoly V bolts, marked with 13 on the head.
Posted on: 2013/1/30 7:11
Re: A15 Head Bolts
Cheers. Looked at site and they do A14 head studs. I'm pretty sure they are the same. Now should I tension to A12 or A14 specs?
Posted on: 2013/1/30 7:14
Re: A15 Head Bolts
From sydney.nsw
A15 ARP HEAD STUD KIT, I'VE GOT SOME IN STOCK . PM ME IF INTERESTED
Posted on: 2013/1/30 7:28
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: A15 Head Bolts
From St. Louis, MO USA
Use the tightening specs for the bolt you are using. Early A12 head bolts have "12" on the head of the bolt and are not as good as the A14/15. The A14/15 bolts have a "13" on the head. The "13" are better. The "13" bolts will accept 54 lb-ft where the "12" bolts only 42 or 43 lb-ft. [Check the torque spec for "T" bolts.]
If using the ARP studs, follow the directions. ARP gives different tightening specs depending on if the nut/bolt uses ARP lube or something like motor oil.
I re-use "13" style head bolts if they are in good condition.
Peter
Posted on: 2013/1/30 14:34
Edited by pjz on 2013/7/23 13:56:32
Re: A15 Head Bolts
Thanks all! Cheers for the offer Peter. I got on to some direct from NISSAN. They are second hand but did the job. Go the Dato!!
Posted on: 2013/2/11 0:26
