« 1 (2)
Re: rims and tyre scrubbing
Yes, stock ute rim 4" wide. 5.5" is fine too. 7" can work if it is a high offset, but most 7" don't fit very well.
Posted on: 2013/2/4 6:53
From Port Douglas. QLD
hitting the top of the gaurds with the side wall of the tyre....would a wider and lower profile tyre work?
Posted on: 2013/2/4 7:09
1200 ute
ca18det
You could try but it's all dependent on wheel offset. If they are sticking out guards it's,not legal anyway.
I couldn't use 165 75 but could use 165 65.
175 70 was fine on 6 inch wide.
Now running 175 50 13 lol.....
Posted on: 2013/2/4 7:19
The top of the guard? How much lowered is your 1200?
Posted on: 2013/2/4 8:14
Will be tyre profile and offset not ride height most likely
Posted on: 2013/2/4 8:38
Hey,
I reckon your tyre ratio is the problem, there's alot of rubber there and the wider rims don't help. You need a smaller tyre profile. 165/55 or 165/6. To get even more low get some 175/50. The alternative is to use some different, much narrower rims.
Posted on: 2013/2/4 8:52
thanks everyone for the feedback
Posted on: 2013/2/4 11:18
1200 ute
ca18det
Shame your not in Melbourne, I have 2 165 65 13 sitting here. Zeetex 101. Even SupAfatto supposed how much grip they carry into and through a corner
Posted on: 2013/2/4 11:31
« 1 (2)
