steering column
Quite a regular
From Adelaide
Steering column seems loose
When you push up on it, it moves about 15-20mm. Seems like the steering column bush is missing but i'm only new to the Datsun game
Anyone had the same problem?
Posted on: 2013/2/6 11:10
Re: steering column
From Brisbane, QLD
Steering wheel moves?
Or the column moves?
Check the U-brackets that hold the column to the steering support and make sure they are done up.
Posted on: 2013/2/6 11:14
71 B110
Re: steering column
From Melbourne, Australia
common problem - missing bush (or broken up and fallen out is more accurate) - remove steering wheel and you should see straight away what is missing, i think the best source for a new one is still Nissan spare parts
Posted on: 2013/2/6 11:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: steering column
Quite a regular
From Adelaide
It feels and looks like the column is moving. Is there a shaft that goes inside another shaft?
I'll have to give Nissan a call and see what I can find
Thanks for your help =)
Posted on: 2013/2/6 12:49
Re: steering column
Make your own out of Nylon
Or buy one from Nissan
The screw in type AU$56
The press fit type AU$26
Photos and details at Steering Column
Posted on: 2013/2/6 20:52
