Oil Pump
From Port Douglas. QLD
hey guys,
i have never removed or replaced an oil pump before. the gasket on mine is leaking.
Is it just a case of unbolt and replace or is there more to it?
oh yeah, l20b engine fyi but figure it would be the same process as a series.
cheers.
Posted on: 2013/2/13 7:21
1200 ute
ca18det
Re: Oil Pump
From Melbourne, Australia
yeah just unbolt and replace, it just has a similar shaft to a dizzy
try not to split apart the spacer and pump housing if that seal is not already leaking (it shouldn't come apart unless you lever that join)
Posted on: 2013/2/13 8:24
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Oil Pump
thanks!
Posted on: 2013/2/13 9:15
1200 ute
ca18det
Re: Oil Pump
On the L-series engine, the timing shaft is driven by the oil pump. Be careful of that.
Posted on: 2013/2/13 21:07
Re: Oil Pump
From Malaysia
the shaft have a dot to be aligned with the oil pump mark.
this thing is important, for the shaft drive the dizzy too.
Posted on: 2013/2/14 1:45
Re: Oil Pump
From Malaysia
1. set the crank to TDC at #1
2. put oil in the pump, and position the shaft dot with dot like picture below, and install it.
the dizzy end should look like this:
install your dizzy after that
Posted on: 2013/2/14 1:52
Re: Oil Pump
Dude you may change that gas kit because if leaking then very dangerous for the burned..what type of kit are you used in you vehicle??branded or non branded??Oil pump is good choice and bolt is the checking point of the oil... http://www.primescales.com/store/?sl=EN
Posted on: 2013/2/14 17:49
Edited by gawqo999 on 2013/2/16 15:43:14
