Perfect ride height
From Trinidad and tobago
Hi folks i want to raises the back of my 1200 sedan because it is low an when i put weight i goes down more,if i modify the spring clamps maybe make them longer if would raises it
back up other than reseting the springs?
Posted on: 2013/2/23 21:34
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Perfect ride height
Yes, you can use longer spring shackles
Or better yet (if it is low now) add a leaf to the spring pack. The 1200 wagon came with a 4-leaf pack for carrying varying weights.
spring shackle
Posted on: 2013/2/23 21:56
From melbourne
DD: Does the 120y also come with same 5th (10mm) spring ?
Posted on: 2013/2/23 23:21
120Y has a 3-leaf spring pack, except wagons have a 4-leaf. 1200 Utes have either 4-leaf or 5-leaf.
In a 4 or 5 leaf pack the bottom leaf is an overrrider, a flat leaf that does nothing until a weighted load comes into play.
Posted on: 2013/2/24 1:00
