« 1 (2)
Re: What do u reckon?
From Port Douglas. QLD
Stock cam 45mmdcoe, looking at datsport or maddat 200b strut/brake combo with the rebuilt front end. At the moment its got 120y strut/brakes which are not up to the job at all. Front end is my #1 priority at the moment.
Posted on: 2013/2/27 2:18
1200 ute
ca18det
Thanks for the replies.Much appreciated info but if anyone can answer my original question that would be great too.
Posted on: 2013/2/27 3:35
1200 ute
ca18det
Original question:
starting to collect bits and pieces for a ca conversion ... what are the chances that i can get the ca in with the current driveline?
Not a question of chance. If you use the stumpy gearbox for CA, it will use the same driveline as the stumpy gearbox for L20B. If you use any other length gearbox, it won't work without shortening the driveline.
Posted on: 2013/2/27 3:43
He will have to swap bell housings for the CA on the stumpy too also the TsilsHaft length depends on where the engine is,situated
Posted on: 2013/2/27 4:03
Yeah i figured the engine position would determine that. is there much lee-way with where i can position it with a maddat crossmember?
Posted on: 2013/2/27 4:12
1200 ute
ca18det
« 1 (2)
