120y steering help
From penrith,sydney,aus
I've got a 77 120y which I was told was all original but the tie rods don't go in to the knuckle arm , the tie rod thread is thicker than the hole in the knuckle arm, can ijust change the knuckle arm over to suit the bigger tie rod or do I have to go the other way
Posted on: 2013/2/27 5:23
2 door 1200 sedan project l20b stroker
Re: 120y steering help
Sounds like you are replacing the tie-rod ends with the wrong ones ...
Posted on: 2013/2/27 6:11
Its how I brought the car, its a 77 model but its like the struts in it are from an early model, can you put early 120y or 1200 drag link and steering into a later model 120y
Posted on: 2013/2/27 6:42
Yes, but they are the same. Perhaps someone was trying to swap in different struts, gave up and sold it to you un-assembled?
Can you post some photos of the struts/calipers and steering arm in question?
Posted on: 2013/2/27 7:37
