Will 17 x 7.5's fit????? ASAP!!!!!
From Sydney
Any know if 17 x 7.5's with 215 tyres fit my 1200 ute, i got stanza struts????
Posted on: 2013/3/1 23:03
Re: Will 17 x 7.5's fit????? ASAP!!!!!
From Logan, QLD
do you have flares?, if you don't they will not fit under the guards, with no offset listed they could be right out the guards, or rubbing your struts/leafs.
Either way 17's are gay on a 1200
Posted on: 2013/3/1 23:13
From Sydney
+ 35 offset? if there simmons they don look gay👌
Posted on: 2013/3/1 23:15
Unlikely on the front, stanza struts push track out on the front and that wide a,tyre will not fit under guards.
7.5 wide won't fit on the front
Posted on: 2013/3/1 23:41
Won't fit on the back either with +35 offset unless perhaps you fit 5mm spacers.
On the front won't fit at all, without cutting the wheel arch and fitting Overfender Flares -- and fitting large spacers like 20mm spacers.
Posted on: 2013/3/2 0:42
