63A speedo question
Quite a regular
From western Canada
Will oil leak ot of the speedo input if I drive my 210 without the speedo installed? Havin trouble getting it to fit without beating out the trans tunnel.
Cheers
Posted on: 2013/3/1 23:07
Re: 63A speedo question
You will get some leakage from my experience. And yes it's a tight fit in a manual tunnel. Worth it though as it's,a strong box
Posted on: 2013/3/1 23:43
If the speedometer cable is disconnected from teh transmission, it won't leak oil at the Speedometer. It will leak oil out of the transmission unless you cap it.
Posted on: 2013/3/2 0:44
Quite a regular
From western Canada
Nice one gents. Working on a 90 degree adapter for the speedo cable to fit into the 63A tranny. Motor is running amazing with the PZ H89 head and tuning of the 32/36. Not running forged bottom end so unsure as to what I should be pushing the car to RPM wise. But everything is else is comin together nicely.
Posted on: 2013/3/4 18:10
Stock A-series bottom end can run to 9500 RPM, but I suggest limiting it to 8500 RPM just to be safe.
Posted on: 2013/3/4 20:26
