Distributor Problems
Quite a regular
From neerim east victoria
Brief history-got a 2nd hand a12 off ebay to rebuild[now finished]getting ready for bench run,when I got it it had a broken dissy cap and the rotor was missing,no biggie I thought,ordered new parts that "dont fit"[its a Bosch dizzy with no vac advance]after much frustrating google searching I cant find any ref to a Bosch dizzy for an A12 only hitachi can anybody tell me if a Bosch dizzy came out in a datsun A12 or what it could be out of or failing that has anyone got a spare stock one for sale in Australia
tks Russ
PS its an early model I think [with the dizzy at the front]
Posted on: 2013/3/5 3:57
Re: Distributor Problems
Bosch distributors didn't come with factory A12 engines ... however Australian-assembled Bluebirds came with a Bosch distributor 1983-1984.
What are the numbers on the side of the distributor? Got pics?
Bosch distributor from Bluebird modified for A12.
Posted on: 2013/3/5 4:05
Quite a regular
sry no pics but its got "JF4"stamped on it-050 cast just below stamp & BOSCH GERMANY cast on the bottom
tks Russ
Posted on: 2013/3/5 4:14
Bosch JF4 -- it may be a Ford Fiesta distributor. See http://datsun1200.com/modules/mediawi ... dex.php?title=EI#Ford_1.1
Posted on: 2013/3/5 4:24
Quite a regular
cant realy tell with that pic as mine has points & no vac advance
tks Russ
Posted on: 2013/3/5 4:39
Quite a regular
after further searching found Bosch JF4 dizzy may have been fitted to early VW's and Alfa Spider's WTF!!& JFU4 fitted to some Fords cant find what the diff is between the 2,tried contacting Bosch Aust but hit a brick wall[no help at all]
So will a later A12[centre dizzy]fit a early[front mount]A12 with out modification?
if not does anyone have a early dizzy for sale?
tks Russ
Posted on: 2013/3/6 20:53
Yes, only the timing plate needs a very simple mod which hand tools can do. See Using Newer Distributor.
Posted on: 2013/3/14 19:56
Not too shy to talk
From Sydney, NSW
Its expensive but this one appears as if it will fit on your front mounting datsun, not only that it is also an electronic distributor which should give you trouble free motoring for years to come.
http://www.ebay.com.au/itm/ELECTRONIC ... ories&hash=item2ec1064e99
Item location is Australia so win for you!
Please note I am not affiliated with this seller, I simply am in the same boat as you and have considered this distributor as an option.
Posted on: 2013/3/14 21:46
1971 Datsun 1200 coupe
From Gold Coast Queensland, Australia
If ucan't find a second hand one try nissan Parts Australia. I enquired about one for my A15 and they quoted $270. It takes 5 weeks to arrive from Japan though. Nissan will ship it to your closest Nissan parts dealer
Posted on: 2013/3/14 21:50
Quite a regular
thanks all for your help I was given a electronic dissy off a Suzuki sierra that I modified to fit,had to machine the housing a bit,shorten the shaft,turn the drive gear upside down havent fired it up yet maybe tomorrow,the only thing I've noticed is that it now turns the opposite way to the inteded Suzuki cap markings ie:Suzuki-clockwise/Datsun-anticlockwise but I can see this being a prob after setting timing,fingers crossed!!!
Posted on: 2013/3/16 8:28
