ca18det microtech base map needed !
Not too shy to talk
anyone on here have a base map for a ca18det microtech ?
thanks
Posted on: 2013/3/17 7:56
Re: ca18det microtech base map needed !
From Brisbane
What model do you have. What pre loaded map is on it now? Contact microtech should be able to send you file
Posted on: 2013/3/17 10:53
Not too shy to talk
microtech lt10 x4 igniter
i bought this second hand and it has tune to suit a worked ca18det i want a base map to see if it will help it run with stock fuel maps etc etc
i have and they said i need to purchase another handcontroller and they will load it onto it to much $$
Posted on: 2013/3/17 11:06
From Brisbane
Do you need to drive it before dyno tune? should idle but thats about it.
Posted on: 2013/3/17 11:25
Not too shy to talk
dont need to drive it but it doesnt idle thats the problem
Posted on: 2013/3/17 12:18
do you have an airflow meter MAF hooked up or using MAP?
Posted on: 2013/3/18 0:38
Not too shy to talk
Map
Posted on: 2013/3/18 4:55
what throttle body did you use? does it have a denso map sensor?
Posted on: 2013/3/18 5:59
Not too shy to talk
its all standard
Posted on: 2013/3/18 6:20
Not too shy to talk
microtech has a inbuilt map sensor i need someone who knows what there doing to come over or should i just take it for a tune ? without it idleing or starting
Posted on: 2013/3/18 6:26
