« 1 ... 4 5 6 (7) 8 9 »
Re: Toying with oot
That fronts not low... The lips just too big. Break it off some.
There's not much under a rotor so how too low?
Chuck an a series carb hat on there and will look stock as a rock almost. Make sure it says Nissan or Datsun
Posted on: 2013/3/13 7:10
Re: Toying with oot
From Adelaide Hills
Yeah want to make a filter for it. The clutch and brake master are higher than the top of the carbie tho.
Ground clearance is fine, where exhaust passes gearbox cross member is a tad low but not a problem. The height issue is all about scrub and corners. I like corners but I haven't even put my wider rims on and I'm having to go slow at the roundabout.
Posted on: 2013/3/14 13:36
Re: Toying with oot
From Adelaide Hills
Now I've done it...
I got a new gear box mount rubber and fixed the exhaust (was hitting body on bumps). Then being overly happy with everything I bought a new battery and salt/water belt... So what's next I say...
Check the plugs, little rich, carby float levels are high (above the windows), read somewhere that lowering them will lean the carby overall... big mistake.
First it wouldn't idle. Tried putting floats back to where they were, now it won't start.
Sad person right here. Now I'm back on the push bike.
Posted on: 2013/3/26 11:14
Re: Toying with oot
From Adelaide Hills
Carb rebuild kit purchased and dyno tune with rotary pro organized. Should be good.
Am taking EOI's with the intention to sell in a few months. Love the ute but need to remove the temptation to modify when I start studying. If anything happens with it I won't have time to fix it and need cheap reliable transport to work.
Posted on: 2013/3/28 21:22
Re: Toying with oot
From Adelaide Hills
Pulled carb apart today, found grit and dirt in bowls, blocked jets, cracked gaskets and a bolt too long that was lifting the air horn. Also learnt that I need to wire up a solenoid to get fuel to the secondaries. Stocked that there is obvious reasons for the current issues.
Posted on: 2013/4/1 13:35
Re: Toying with oot
Shame you're selling it mate! Looks like its definitely been a part of you, and if you kept it I bet your kids would have some wicked fun it when the grow old enough!!
Posted on: 2013/4/1 13:46
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: Toying with oot
From Adelaide Hills
Yeah would love to keep but hopefully moving interstate next year for work if everything goes well and doubt I will be able to register it.
Posted on: 2013/4/1 22:09
Re: Toying with oot
From Adelaide Hills
After finding blocked jets, dirt and cracked gaskets the carbie rebuild still didn't fix the problem. Turned out to be a combination of ignition power supply, immobiliser and butterflies too closed.
Running awesome now. Very happy.
Still want to redo some wiring, mount a tacho and try to rig up the rx7 speedo cable to the datto dash. Also want to get a dyno run/tune to make sure its as good/safe as it can be and then the wife gets to make some carpet and door cards... if I'm lucky.
Posted on: 2013/4/10 9:11
Re: Toying with oot
Sounds awesome! Nice work, think we need a movie just to make sure it really is going ;) haha
does this mean you're going to keep it now?
Posted on: 2013/4/10 9:17
1200 Ute - Mild A12
Re: Toying with oot
Check out a place in Flemington Victoria called speed screen. They make cable adaptors like the one your talking about
Posted on: 2013/4/10 10:00
