WTB ...Wheel spacers
From San Diego,California
I'm looking for some wheel spacers or adapters for my Datsun 1200 coupe I need them to be at least 15mm thick I came up on some Z wheels and they are -30 offset they fit great in the back..not so much in the front.Tires are 195-50-15. Any one ??
Posted on: 2013/4/8 3:12
Mahalo Victor
Re: WTB ...Wheel spacers
From Brisbane, Australia
4/114.3 M12x1.25 15mm bolt on spacers are all over ebay. cheap too.
Posted on: 2013/4/8 3:26
What's hub centric mean?
Do Datsuns use those?
What Bore size?
Posted on: 2013/4/8 3:46
Mahalo Victor
http://www.ebay.com - search for 4x114.3 M12x1.25 wheel spacers
Hub-centric means they center on the hub. Datsun 1200 uses 71mm hub registration diameter - so 66 mm hubcentric for S13 won't fit, unless the center hole of the spacer is drilled out larger.
-30 offset wheels will stick out the side of car. But +30 wide wheel need a +15 spacer on the front.
Posted on: 2013/4/8 3:47
When I search for that on ebay bore size is 66.1 no 71 or 73
Posted on: 2013/4/8 3:52
Mahalo Victor
Bolt-on spacers do not need to be hub-centric -- they will center on the lug nuts. Just need the center hole 71 mm or larger.
Have them machined to 71mm or 72 mm center hole
Thanks for 1200rallycar for measuring this!
Posted on: 2013/4/8 6:05
I found a set but the lugs are 1.5 instead of 1.25 will that work? and they are 1 inch?
Are 1 inch going to work ? Or is it to much?
Posted on: 2013/4/8 14:39
Edited by CrazyHawaiian on 2013/4/8 17:33:56
Edited by CrazyHawaiian on 2013/4/8 17:34:55
Mahalo Victor
1" is 25.4 mm
1.5 thread lugs will work, but will require 1.5 lugnuts.
Posted on: 2013/4/8 19:01
I'm surprised you can't find them in the 'states. I bought a pair of 15mm 4/114.3 spacers with 73.1 centre bore and 1.25 thread pitch last week off ebay for $60.
maybe double check you are searching international sellers on ebay?
Posted on: 2013/4/9 2:23
