Help! Z18et dizzy
Hey I'm halfway thru doing a z18et conversion and I need to find out what type of dizzy is in it. Does anyone know if it has a optical. Magnetic or hall affect. Also If anyone knows what wires are what? It ha 3 wires on it red blue and black. Any help would be great
Posted on: 2013/4/16 14:07
Re: Help! Z18et dizzy
From Snohomish, WA USA
1. Black/white to Ignition
2. Red to Negative side of Exhaust Coil
3. Blue to Negative side of Intake Coil.
Posted on: 2013/4/16 16:36
Edited by datsa73 on 2013/4/16 22:35:52
Edited by datsa73 on 2013/4/16 22:37:59
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Nearly all Datsun EI distributors are magnetic, using a reluctor and a stator. Later Nissan started using some optical triggers, such as the famous E15ET engine.
You can easily tell these by removing the distributor cap. If you see a star-shaped ring or a pointed rotor (under the spark rotor) it is magnetic. If you see a metal covering all the bits, you will find when it is removed that there is a 360-degree wheel in there (optical trigger wheel).
Posted on: 2013/4/16 23:24
