Re: Diff shortening
Or just use a Nissan H190. Some are shorter than a 1200 diff so need no shortening.
The biggest cost in "shortening" is extras that are really not part of shortening: Brake rebuild or disc-brake conversion, new LSD, new gearsets, new bearings etc.
Mad Dat sells a shortened R31 diff with disc brakes for Datsun 1200 that is only $2345. So that is the top-quality price. Mad Dat Diff.
Posted on: 2013/4/19 2:44
Re: Diff shortening
With,no centre dd I think
Posted on: 2013/4/19 3:30
Re: Diff shortening
From Narellan,Sydney
Dd I'm running 10" wide rims with 5" lip and making 450hp.not sure the h190 will hold up lol I'm going to shorten hoisting then get some billet axles made then rebuild brakes add new bearings etc will be good when its finished :)
Posted on: 2013/4/19 3:48
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Re: Diff shortening
And dd that price dosnt include a centre
Posted on: 2013/4/19 3:49
Re: Diff shortening
From WA perth
it,s pretty pricey.you can get it a lot cheaper than that an with a rebuilt centre r31 LSD
Posted on: 2013/4/19 6:13
Re: Diff shortening
I can make u a hilux or r31 diff with whatever width u require and whatever leaf spring width u need with r31 or commodore disc brakes. I use masterline axles out of america made by mark williams. Pm ur requirements I can give u a quote. Top quality work out of one of the best diff companies in australia
Posted on: 2013/4/19 14:20
Re: Diff shortening
Yes, shortening does not include fitting a centre. Two seperate things.
R31 (Borg Warner 78) can't handle 400 ft lb of torque can it?
Posted on: 2013/4/19 17:41
Re: Diff shortening
Not too shy to talk
From South California, USA
hey guys i saw the post and i have a question. I have a H165 4.87gr, anyone know where i can buy a ring and pin so i can get it down to a 4.11gr? ive seen some online but they are 400$-500$
0_0
Posted on: 2013/4/19 17:57
1973 Datsun 1200 Coupe
SR20DET stock turbo.
Re: Diff shortening
Start a new topic please, this one is about shortening.
Posted on: 2013/4/19 18:01
Re: Diff shortening
Maddat for the.... I have maddat diff and I only went with them because it came with everything ready to bolt in... Also for the price I couldn't get one made in Perth for the same price..,,
Posted on: 2013/4/20 5:55
Edited by bailz on 2013/4/20 6:13:37
« 1 (2) 3 4 5 »
