« 1 (2)
Re: 1975 120Y Stanza SSS wheels
Yeah I know the difference between 120Y, Sunny and Stanza. Several lifetimes back I used to have a Sunny mit A15, twin Hitachis and 5 speed. The female who owns the present 120Y coupe had a Stanza before some clown flogged it. Actually this is her second 120Y ... first was used on the road for a few years before being retired as the donor car for the restoration job. Her daily driver is a Mercedes A160.
Posted on: 2013/4/21 9:24
From Brisbane, Australia
you could buy some wheels that fit... saves messing around with strut conversions just to get the Stanza wheels on there. If you're worried about a 30mm spacer making the tyre hit the gaurd, the Stanza strut conversion will easily be at least that much wider track as well. And if you do the Stanza front end, you end up with a much wider front track to rear track, which looks pretty silly.
Posted on: 2013/4/21 23:06
Also doesn't add to great stability in some driving situations.
Posted on: 2013/4/21 23:16
All good points. The Sunny looks off with the wide front track, so I wouldn't make my 1200 look that way.
But they do look good, eh?
Did those wheels come on anything other than Stanza SSS?
Posted on: 2013/4/22 0:16
« 1 (2)
