A12 head to A14 head???
From gold coast
Just wondering if you can put a A14head on a A12block the head is a round port if that helps
Posted on: 2013/4/28 6:21
Re: A12 head to A14 head???
From sydney.nsw
yes,on later a12s, also need to change inlet to suit a14 head
Posted on: 2013/4/28 6:23
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
A14 is fitted with a late-model cylinder head.
Fitted to early A12 block: Bolts on, but mod needed for oil passage.
Fitted to late A12 block: bolt on. No mods needed.
Posted on: 2013/4/28 6:30
From gold coast
Ahhhh that sucks that's my problem so how do you mod the oil passage or am I just better off finding a late model a12. Manifold is all good I've mad one form motorbike carbs
Posted on: 2013/4/28 7:56
From sydney.nsw
do you have a early a12, wheres the dizy located, front or middle of engine
Posted on: 2013/4/28 8:27
From gold coast
The dizzy is at the front it's the original motor and its a 71 sedan
Posted on: 2013/4/28 8:32
From sydney.nsw
the mod is not hard to do,its just drilling a small hole(3-4mm) for oil to go to rocker gear.
Posted on: 2013/4/28 9:25
From gold coast
Ohk sweet and obviously mod the head gasket as well cheers for that ill see how I go
Posted on: 2013/4/28 23:30
