SHORT boss kits now on ebay
Quite a regular
hi all,
I'd just like to inform those interested, i have now listed the short boss kits i designed and made
ebay link
Posted on: 2013/5/1 13:20
Re: SHORT boss kits now on ebay
Yes please
Posted on: 2013/5/1 13:23
Car free
From WA perth
what do you do with the blinber switch
Posted on: 2013/5/1 14:20
Quite a regular
The blinker switch? It can easily be bent back a little to make room for the new steering wheel position
Posted on: 2013/5/1 22:52
And the cancelling roll pins are they there to?
Posted on: 2013/5/1 23:04
Car free
Quite a regular
Definately, It's all covered in the advert description
Designed and made by a 1200 enthusiast to be just right
Posted on: 2013/5/1 23:27
From Sydney Aust
Just had a look and purchased one. Thanks for that. They look exactly what i am after for my ute.
Posted on: 2013/5/2 2:32
bobbyroonay
So you have to have the spacer plate on top of the wheel to run the horn?
Is it possible to pick up too?
Posted on: 2013/5/2 10:56
From Townsville, Qld
might have to get myself one of those down the track
Posted on: 2013/5/2 11:06
Quite a regular
thanks for the support
boss1200ute: it is basically setup so you can do what you please
with the spacer on top of the wheel as you say this allows you to run the steering wheel in the lowest position (almost flush with the end of the spline on the steering column) but still have a horn button
if instead you put the spacer behind the wheel (between wheel and boss) then the wheel will be 20mm closer to you but you can mount the horn flush to the wheel (and therefore have the wheel in the lowest possible position but still have a horn flush mounted) - and this will still be lower than all other boss kits available
or you can run no horn on the wheel as it is legal to have the horn as a push button on the dash instead
then it depends if you have a dish wheel and quick release etc. but basically this boss gives you the freedom to best mount anything you may want in the way you want to
Posted on: 2013/5/2 11:51
