Putting doors back together
From Goulburn NSW
Hi guys I need to know whether or not the rod for the inside door release goes on the inside off the window regulator.Oh guys I have worked it out it goes underneath the door skin,is that correct?
jpg  8361.jpg (56.67 KB)
14333_5187600a6cae9.jpg 593X387 px
Posted on: 2013/5/6 8:47
Re: Putting doors back together
From Narellan,Sydney
I Can't remember how mine was although i put different regs in.i hope your putting this back together after being painted
Posted on: 2013/5/6 8:50
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Goulburn NSW
Yes mate after its painted.I have that many bolts,screws and nuts in bags I have to keep on looking at them so I don't forget.And that's with them labelled.I also have another question,with the bailey channel is it installed in 2 sections as I thought that it would have the front half done the vertical part on the 1/4 window side and on the vertical side at the back off the door so the window can be put in place and then bolt the 1/4 window in place so the window is in its slot then glue the top part off the door.So basically the bailey channel will be in 2 parts.
Posted on: 2013/5/6 8:55
Edited by mcdat on 2013/5/6 9:18:37
Edited by mcdat on 2013/5/6 9:19:31
I know lots of people that label bolts and that really seems to make life hard.to be honest when I did mine I only labelled my regs and threw every other single bolt in the bin.then when it come time to put back together I bolted it all up with brand new stainless bolts,washers and nuts.the regs only really go 1 way so wasnt really hard.not sure about the bailey channel as I deleted my quater window
Posted on: 2013/5/6 9:28
From Goulburn NSW
This is what I mean.
jpg  door.jpg (132.55 KB)
14333_51876a132fd5a.jpg 640X864 px
Posted on: 2013/5/6 9:30
Looking at that yes it would be in 2 peices
Posted on: 2013/5/6 10:03
From Sydney NSW
i didnt do mine in 2 pieces, but would fit way better with that corner cut like you said
Posted on: 2013/5/6 10:08
1200 Ute
That's how the corners should be cut notching it out at 45degrees
Posted on: 2013/5/6 10:27
Not too shy to talk
From Sydney, NSW
It goes in between the door and the door skin.
Posted on: 2013/5/6 10:49
From Goulburn NSW
Yeah worked it out after I posted,cheers anyway.
Posted on: 2013/5/6 10:51
