a15 supercharging
From Kelmscott Western Australia
Gday
Just thinking of doing a carby supercharger setup on my a15 with a 32/36 weber and a sc12 charger really need some power on acceleration really need little bit of advice on these friend of mine had this and had a problem with it kept pinging and had a flat spot
Any info on this setup will be much appriciated
Posted on: 2013/5/13 14:44
Re: a15 supercharging
Pinging is a result of the timing, or lack of. And the flat spot is carburettor adjustment. Fine tune those two aspects and you're good to go.
They are the two most important ingredients when trying to make optimum horsepower.
Posted on: 2013/5/13 16:31
1. Do not remove the vacuum advance. It will not interfere with a supercharger, but more importantly will serve to hold the advance plate fastened.
2. Reduce the overall timing. Easiest way to do this is to set static (idle) timing to 0-4 degrees, which will reduce high RPM timing to ~25-29 degrees. Further tuning involves modifying the advance weight slots inside the distributor.
Posted on: 2013/5/13 20:29
From Freo
pinging could be too much compression more likely...
and I hear the DGAV can have a hard to find lean spot with a blower...
Posted on: 2013/5/14 1:12
A15 PSI Project Motor
'72 CB750k,
I have the sc12 (well my old man... Lol, but I claim it :P) and injection on the a14 in a coupe, that thing hammers!
Posted on: 2013/5/14 1:33
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Cheers for advice people im concidering of efi sc now sounds like from stock1200ute they go pretty good
Posted on: 2013/5/14 4:28
You can also go twin screw more efficient and extra using less capacity
Posted on: 2013/5/14 4:44
Anyone got any good photos and videos of a carby setup
Posted on: 2013/5/14 12:33
Thats our setup its with EFI though...
jpg  engine bay overview.jpg (198.26 KB)
13572_51922384740a1.jpg 730X429 px
Posted on: 2013/5/14 12:44
From sydney.nsw
heres a setup i have ,a little amr-300 pumps 11 lbs with 350 holley.custom inlet/exhaust.works great.simple.thinking of selling it.
jpg  IMGP0644.JPG (64.61 KB)
9764_51922373c7148.jpg 548X411 px
jpg  IMGP0649.JPG (62.28 KB)
9764_5192240ed002b.jpg 548X411 px
Posted on: 2013/5/14 12:45
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
