electronic distributor coil
Quite a regular
hi all, could someone tell me what type of coil to use with a electronic distributor on a a12 motor at the moment I have a bosch 40
Posted on: 2013/6/13 7:07
Re: electronic distributor coil
From sydney australia
Most people including myself, use the HEC115 coil from Bosch. If you use the Gt40 style coil, the motor will start but wont be responsive.
Posted on: 2013/6/13 10:30
GT40 is a low-energy coil suitable for use with points distributor or electronic distributor. Since the GT40 has a built-in resistance, you must bypass the external ballast resistor when used with the stock points distributor. The GT40R is slightly different and uses the original ballast resistor.
Of course a high-energy coil is best for use with electronic ignition. The Bosch HEC715 or Nissan Pulsar coil work well.
Posted on: 2013/6/13 21:39
Thanks Dave, for spotting my mistake , it's the HEC715, not a 115. My only excuse was I was flat out working on the car all day, & was tired. Teach me to lean the motor out then drive to Coffs Harbour & back. Number 4 cylinder has 50 Pounds on the compression guage. Looks like broken rings. Was swapping an A12 in to get the car running, will finish this weekend (fingers, toes & everything else crossed).Then
Posted on: 2013/6/14 10:38
