Brake Booster
From Trinidad and tobago
Hi my booster is making a suck sound for about 5 seconds then stops.This happens when i switch of my engine.Any suggestions as to what might be the problem??
Posted on: 2013/6/18 0:40
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Brake Booster
From Sydney NSW
got a one way valve on the line?
Posted on: 2013/6/18 1:48
Re: Brake Booster
Yeah.How to check if its defective?
Posted on: 2013/6/18 2:42
Street Sleeper!
Re: Brake Booster
Take off the valve and blow air into it with your mouth. The air should only travel one way. If it travels both ways the valve is defective.
Posted on: 2013/6/18 2:56
Re: Brake Booster
You use the same technique on pooper valves Jeff
Posted on: 2013/6/18 3:03
Re: Brake Booster
I had a bad feeling you were watching this thread :)
Posted on: 2013/6/18 3:12
Re: Brake Booster
Im looking at ways to eliminate my booster in the stanza. I hate the thing's
Posted on: 2013/6/18 3:18
Re: Brake Booster
From Sri Lanka
Hi darrenwilson
I am keen to see what happened finally, i had the same issue but there was nothing wrong with valve it works only one way, but i have brake but booster doesn't work now on my b310
thanks
regards
sumith
Posted on: 2013/6/21 9:12
Re: Brake Booster
Sounds like the booster is leaking. Not the one-way valve neccessarily.
If the booster is leaking a little like this, you can compensate for a good idle by adjusting the carburetor mixture screw. It doesn't solve the problem, but lets it the idle be steady. Better to fix the problem (replace the booster).
Posted on: 2013/6/22 7:22
