« 1 2 (3) 4 »
Re: engine problem
Quite a regular
if that's right look like I will be changing the rings does any one else know
Posted on: 2013/6/26 10:31
Re: engine problem
Quite a regular
hi, done a compressing test all 165 , if I have to change oil rings can you buy the oil rings only and where?? any body would know. thanks
Posted on: 2013/6/27 2:41
Re: engine problem
From Sydney
165 is healthy. as already mentioned, give the stem seals a look. may even be a dodgy PCV valve.
Posted on: 2013/6/27 2:52
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: engine problem
Quite a regular
thanks I have cleaned the PCV valve and where would you buy another one from
Posted on: 2013/6/27 3:29
Re: engine problem
Quite a regular
Re: engine problem
From Sydney
nissan dealer. part number. 11810-A3500 ASSY-CONTROL VALVE CRANK CASE EMISSION A12/14/15
Posted on: 2013/6/27 4:03
1970 KB10 Coupe
S13 caliper b...
Re: engine problem
Quite a regular
hi benny, I took the hose off the PCV valve and it sucking good so it couldn't be that
Posted on: 2013/6/27 10:20
Re: engine problem
Right, the hose isn't usually a problem.
To test if the valve is the problem, clamp the hose shut (using vice-grips) and drive it around. If the problem clears up, the valve is the problem.
Posted on: 2013/6/27 16:25
Re: engine problem
Quite a regular
From neerim east victoria
If it blows smoke under load ie:going up a hill its usually rings,if a good test is to drive up a hill under load if you have a trail of smoke its rings,coast down a hill in 3rd gear and only apply the throttle at the bottom if it smokes then,then its probably valve stem seals,as benny said its good cyl comp so I doubt if its rings,and don't forget a12's have two seals per valve,I've seen quite a few heads that haven't had the small "O"ring fitted to the top of the stem
Posted on: 2013/6/27 23:48
Re: engine problem
Quite a regular
hi Iam back took it for run no smoke up hill or down put in my garage then try to start it but it would not go, got a new dizzy cap, new points, rotor button, now back firing in carb, and petrol coming out of top carb this engine is driving me nuts any ideas
Posted on: 2013/7/11 11:07
« 1 2 (3) 4 »
