What carby choices do I have?
From Brisbane, Narangba
I'm looking for a carby to suit my mild a14. At the moment it is running a stock carby and doesn't really offer much above 5000rpm.
Could I just fit a a15 carby to make it go a bit better + plus it bolts straight onto the manifold.
Or is there a manifold thay I could buy remembering it is not an oval port head to suit SU carbies ie. 2 strombergs
Also I don't want to muck around with webers. I already have a 32/36 sitting there but don't want to stuff around changing jets.
Lastly are there any other good carbies that will bolt straight on to the stock manifold.
Thanks
Posted on: 2004/5/7 10:12
Re: What carby choices do I have?
From South Africa, Bloemfontein
Hi Freak
The best advice I can give, and I think alot will agree with me, is to put on the 32/36 that you already have.
Even if you put any other carb on that you want to do, you will need to tune it.
Rather put the 32/36.
Is there any guys out there that can maybe help him with some jet settings for his 32/36 on a A14?
If someone here can give you some jet settings for your application then you will be halfway there in solving your problem with jetting.
Goodluck
Posted on: 2004/5/7 10:34
1977 Datsun 1200GX
Yeah, but if I just put on a carby off a 1500-1600cc motor jetting should be pretty good. Also Su's are easy to do, there is only a single needle that needs to be changed.
Also 32/36 is up for sale. I'm pretty sure I don't want to use it.
No one can really tell correct jet sizes.
Posted on: 2004/5/7 10:46
Freak, the A15 carb is the same carb as the A12 carb (Hitachi DCH306). So it still won't give you much over 5,000rpm.
A carb for an L16 will be jetted differently from what an A15 needs ... any way you look at it, to get a bigger carb you will need to rejet it -- or pay someone else to do it by buying their service or already-jetted carb.
If you use the B210 jetting listed here on the site for the 32/36, your engine will run well.
Posted on: 2004/5/7 15:31
