South Africa 1992 a14 ute build
Good Morning.
I have been using the information on this site to help me work on my car, and i would now like to start a build thread and get some specific help on some subjects.
The car's details : a14 ; one owner ( my father ) ; original paint
Recently acquired minilights - 13x7jj et-8 with accelera 165/55R13. The car has been lowered approx 30mm front and back, but I am now looking to get it as low to the ground as possible, while keeping usabilty as a daily driver. the ride height can be seen in the pictures.
My questions : does anybody have any advice and tips for shortening the struts.( car has newish monroe struts in with standard (very soft ) springs )
Will a leaf flip at the rear get me as low as re-tensioning the rear leafs to a flat position?
All done on a tight budget.
All your experience with doing such things will be greatly appreciated.
Regards
jpg  IMG_3238-1.jpg (106.83 KB)
17260_51c6a2feeec3c.jpg 700X467 px
jpg  IMG_3239-1.jpg (127.86 KB)
17260_51c6a3109504f.jpg 700X467 px
jpg  IMG_3240-1.jpg (117.49 KB)
17260_51c6a319a0d96.jpg 700X467 px
Posted on: 2013/6/23 8:33
Re: South Africa 1992 a14 ute build
From mandurah
Nice ute mate
Im running the same tyres as you , they fit pretty well!
As for the rear , flip the bottom leafs to the top and buy some 2.5 or 3 inch lowering blocks and itll sit nice and low
As for the front , never done stock struts but check the wiki itll have some info on what insert to use
When I did my stanza struts I did the following
Find inserts shorten than stock , with the same OD to fit into the strut
Cut perch off and grind welds off
Cut strut tube , if new inserts are 100mm shorter , cut strut tube at 150mm , then with the cut off piece , cut the top 50mm off as its got a thread in it to retain the insert
Sit threaded part of tube ontop off the strut tube , weld back onto tube and reinsert insert
Weld perch or coilover sleeves on and reassemble
Posted on: 2013/6/23 17:12
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Thanks for that info about shortening the struts, now I now about that top threaded part.
I am going to do the back tomorrow and get the struts out after that and see whats happening
Regards
Posted on: 2013/6/23 17:35
Flipped the bottom leaf to the top, got about another inch and a half lower at the rear. now to flare the arches befor i can go lower in the front
Anyone have any tips on pumping out the front and rear arches ?
Posted on: 2013/6/24 20:05
Posted on: 2013/6/25 1:42
I've tried rolling the fenders but its become clear that something much more is required. The back is fine, but for the front to go lower, the arch needs to get out of the way
jpg  IMG_3258.jpg (57.26 KB)
17260_51c99b4f656e0.jpg 700X467 px
jpg  IMG_3242.jpg (70.55 KB)
17260_51c99b5c25238.jpg 700X467 px
Posted on: 2013/6/25 14:30
Your going to need a combination of negative camber, pumped guards and possibly longer lower control arms for more neg camber for those front wheels to tuck under..... And then I still don't think they will
Posted on: 2013/6/25 15:44
Can i make camber tops that are mounted higher up, and effectively get camber and lower the car without having to shorten struts ?
Also, would anyone know why both my indicators come on when I just put one on?
Posted on: 2013/7/8 7:51
Nice ute! What camera are you using?
Posted on: 2013/7/8 11:00
canon 500d brother,
Anyone know about this indicator story ? get hazards when i just want to turn ? indicator unit faulty ?
What you rate ? Please
Posted on: 2013/7/9 22:13
