Mech or electric gauges?
From Narellan,Sydney
About to buy my gauges just wondering people's thaughts on mech or electric for best readings? I'm guessing electric and think I want electric.not a fan of the fluids running in the cabin.but thaught I'd ask anyway
Posted on: 2013/7/21 9:44
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Re: Mech or electric gauges?
Illegal run fluids like that into cabin anyway. Go elec.
Posted on: 2013/7/21 10:38
Yeah was thinking electric just after other people's opinuons thanks mate
Posted on: 2013/7/21 11:02
From Melbourne AUS
for best readings id choose mechanical
Posted on: 2013/7/21 12:31
1973 B110 A12
From Snohomish, WA USA
My Fuel pressure is electrical. Oil and Boost mechanical. Even though the Boost is an air/fuel mixture, I don't expect the line to leak. Same with the Oil line.
I think my next winters project is to replace all the dashboard gauges. My speedo doesn't work and neither does the tach. The tach on the top of my dash does work and that's the one I look at along with boost, fuel pressure and lean/rich fuel mixture gauges. The temp, volt and oil pressure gauges are mounted on the tranny tunnel hump to the heater/fan box. They are visible there with just a quick glance down.
For the dashboard, I'll be replacing with all electrical. It will mostly just be the speedo, gas gauge and some warning lights.
Posted on: 2013/7/21 17:21
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
