common modifications
From Brisbane, QLD
Want to know the common modifcations to make my 1200 go that little bit harder
Posted on: 2013/7/20 15:05
Re: common modifications
Viagra?
Common is carbs maybe cam. Xhaust too. Im being vauge as what do you wan. Torque or top end.
You may need consider brakes suspension gearbox and diff too.
Posted on: 2013/7/20 19:53
Some fairly common modifications:
Electronic ignition.
Weber 32/36 carburettor.
A14/A15 engine swap.
Oval Port Head.
Extractors.
Camshaft regrind.
Posted on: 2013/7/20 20:48
From Malaysia
electric fan rather than pulley. lighten the flywheel a little bit, better clutch.
Posted on: 2013/7/20 20:55
L series
Posted on: 2013/7/21 10:06
From Malaysia
hahahaha +1 for an L.
Posted on: 2013/7/21 10:23
From south australia
I read a post a long time ago.
I drilled holes in my chassie rails to make the car lighter.
DONT DO THIS.......
How about a a14/15 conversion....
Posted on: 2013/7/21 16:02
The meaning of life is not in the fridge..
Its in the shed....
Lighter means quicker accleration. Lightening holes are used by race cars.
To go harder, the most common modifaction is larger engine: A14/A14, L16/L18/L20B, or CA18DE/CA18DET.
Posted on: 2013/7/21 19:40
